ancap-usa.com: quality Italian porcelain coffee serviceware in the USA
Olympia Cremina lever pin design
Postby PavoniMaster on Fri Nov 18, 2011 2:51 pm
What model year did the Cremina lever pins change back to a circle clip design?
I really like the look of the 2002 model with the bolts holding the lever pins in place as opposed to the circle clips. I thought that the bolts were a really solid design. I understand that there is no sideways play in the lever with either method, I just prefer the clean design look of the bolts.
I believe that there was a update with the 2008 model, can any one confirm if this is when the change was made or was it with the new 2011 model?
PavoniMaster
Postby dick-san on Sat Nov 19, 2011 3:12 am
I agree that the bolt design looked better -- & easier to work with than cirClips. I'm pretty certain the change back was with the new 2011 which otherwise seems to be a better design.
--dick
dick-san
Postby Richard on Sat Nov 19, 2011 11:38 am
PavoniMaster wrote:What model year did the Cremina lever pins change back to a circle clip design?
A Cremina new midsummer 2009 has the snap rings.
Richard J. Wyble
Richard
Postby tekomino on Sat Nov 19, 2011 12:05 pm
Would be nice to source pins with bolts for replacement. It woul ease the maintenance...
Refuse to wing it! http://10000shots.com
tekomino
Postby PavoniMaster on Sat Nov 19, 2011 4:07 pm
Looking at the photos on the Cremina Olympia website today, they look to be the same photos from early 2009 when I was looking to buy a Maximatic & Moca. I guess they probably made the change back to clips with the 2008 model and I believe that is when the multi piece piston from the 2002 model was reverted back to the single piece?
Some one had posted about sending the 2002-2007 grouphead design, back to Olympia to be ground out or modified to work with the latest post 2008 piston design and I think that Olympia no longer has the seals for the 2002-2007 piston design, Can any one confirm this?
PavoniMaster
