Grant wrote:Problem is afterwards when lifting the lever, the water exiting the head is not just water, it is hissing/steaming similar to what I am seeing like an HX cooling flush.
Grant wrote:Just replaced all of them....brand new/lubricated with Dow seal lube etc.
HB wrote:I don't understand. It is water exiting a steam boiler, why wouldn't you expect some hissing and sputtering?
TUS172 wrote:So is it while you are lifting the lever or at the top of the stroke? If it is at the top of the stroke then Dan is right... you should expect hot water and some steam. Did you used the steam wand to let off false pressure? Then you still have a build of of some steam in the tube to the grouphead. Even when you use the lever to let off excess pressure you will still have a bit of steam in the initial pull.
The hole that the hot water enters the chamber of the grouphead is less than .125" in diameter. The diameter of the tube that feeds the grouphead is larger than that. And also the grouphead chamber is large enough so that by the time the hot water actually hits the screen it has traveled the length of the grouphead from near the top to the screen... it is going to mix with air and exit the screen not as just hot water.
If it is during the stroke then you (or whomever did the work) may have clipped the seals while putting in the piston shaft and piston into the grouphead.
Grant wrote:Hi all,
Playing around with a Cremina, and am trying to determine is this is just a normal function of the machine, or if there is something else wrong.
Let the machine heat, bleed the false pressure, and let it heat up a few minutes more.
I have been dropping the pressurestat adjustment lower and lower...just not sure if this is normal...I have watched a youtube video where some seem to hiss/sputter, and others not.
What should I be looking for?
tks...
Grant wrote:Never having used a Cremina before, I guess I should be asking if this is "normal" for a Cremina. Watched a cremia video on youtube and the stream of water from the head seemed to be quiet, much like the stream after the flush on an HX.
bobcraige wrote:It is very unclear, at least me, what you are talking about. Do you have coffee in the basket when you are doing this? Is the portafilter even on the machine? Where is the hissing steaming that you describe coming from, the spouts, the shower screen, the piston shaft? It is very difficult to help without any clue what it is you are asking.
