Olympia Cremina boiler holes
hi,
i have a problem with my cremina. the joint between boiler and brew unit/lever unit had a very tiny hole. a goldsmith fixed it. now another very tiny hole appeared.
what is the long term solution for this problem?
kind regards, a.
kind regards, a.
Depends how big the hole is. Pics? I found loctite 290 the be very useful for some pin holes in a boema machine I restored. You need to heat up the boiler with a flame torch and drop a few drop so it penetrates into the pinhole.
This thread might help.
Using Loctite 290 to seal small cracks and pin holes in boilers
Check out https://www.youtube.com/watch?v=N8F8H4K8ws4. This is Doug describing pinholes, thread-lock and the fact that most pinholes are actually self sealing.
Chris
Chris
Chris
LMWDP #476
LMWDP #476
