wobblyeyes wrote:I just picked up an Olympia Cremina 67 and it's missing the portafilter(apparently, according to this forum, not uncommon!).
I'd like to resurrect the machine but I'm figuring I'll have to make one out of brass or SS pipe. shouldn't be too hard if I make it "naked"
Could someone get me the diameter of the inside and outside of the portafilter(without the tabs).
I'll also need the diameter of the cup(measured at the high point where the cup meets the gasket.)
I think I'll need it to the nearest 0.5 mm, even closer would be better.
I believe Lino has a better set up for the job in multiples, he has CNC and the buying power. Bottomless PFs are one of his specialties.wobblyeyes wrote:Wow, thanks for those measurements, That should get me most of the way there.
I'll have to pass on the offer to make one. My shoestring budget won't allow it.
timo888 wrote:I would really like a brass bottomless portafilter/custom handles combo
Regards
Timo
P.S. I think Lino asks that you send him your PF (if it's non-standard) and he turns it into a naked one. He won't have a cache of Oly portafilters on hand.
