timo888 wrote:On the choice of material...
The Oly Club manual recommends running the PF under cold water between shots to keep the Club's group from overheating. To that end, could the naked PF be made from brass instead of stainless? Less wear and tear on the group slots too.
Regards
Timo
Hmmm.... The little wheels are turning.
Hey Richard, thanks for the DXF offer. I think I'll take you up on it, even though I'm getting a PF to hold in my hand and measure too.
For what it's worth, here's the business side of My Shop
The "Santec" pictured at the bottom, outside, early during disassembly, was, isn't now, but will besoon, a CNC machine. My Bridgeport looked much worse than that when I first got it home...
Also, all the bottomless PFs I cut are done inside the Tupperware (that everyone asks about) that's sitting on the rotary table. It contains the chips.
ciao
lino
espressme wrote:The "Santec" type of machine is a real solid performer. very sturdy and stable. Way, IMHO, stronger and more rigid than the Bridgeport types. I've CNC programmed and machined with all the various type and that is a winner at the price point. The last reasonable priced machine. We had a CNC"Lagun" and some CNC "Miltronics?" from Minneapolis of that style and they never let us down from chatter.
Did some machine tool rebuilding meself and can see that you did a great job. That Clausing sure beats my Craftstsman 12" and my Chicago mini mill.
What CNC controller are you planning to use?
TUS172 wrote:Lino,
I really like your setup. Much better than mine was and the Clausing is in great shape! What is it 24" between centers and 10" swing? I had an old Logan Model 200 built in 1943 but was in mint condition... Belt drive and had to change out gears in order to vary turning/feed and threads... Just sold it last winter to a guy from Mass. He loves it... I am looking to replace it after I move to NH this summer/fall.
Portafilter sent...
lino wrote:Regarding the mounting of the handle, since the wall of the PF is thicker than stock, what about drilling thru the wall and tapping.
Then two options are available:
1) use a custom handle that screws directly into the wall of the PF.
2) use an "adapter shaft" that threads into the PF on one side and has length and threads to mimic the original PF so that original handles can be used.
lino wrote:[
lino wrote:Hey Guys,
I've got pretty much no idea of cost right now, except that it will likely be on the far side of $100.
ciao
lino
timo888 wrote:It is too soon, I think, to ask "who's in?" if we don't know the details. Whoever ends up making these, Lino or Richard, will want to find out what features are desired, and then come up with a description of the item, and a price.
Whether I am "in" depends on a number of things:
-- choice of material (I prefer brass for its heat-sinking capacity)
-- chrome plating rather than simple polishing for aesthetic reasons (so it doesn't get blotchy)
-- compatibility with original handle thread
and last, but certainly not least
-- the precise dimensions near the rim support wall.
The tolerances near the rim are very small, yet there may be variations over the years in the dimensions of the portafilters. For example, I have spent close to $100 on baskets that are said to fit but don't quite fit. They are very likely to sneeze because the rims sit a fraction of a millimeter higher and so press tighter against the gasket than the originals do. The replacement baskets fit so tight that they also place a lot of stress on the handle when they're being locked in, and the repetitive lateral stresses have cracked two handles. The original baskets fit perfectly (a little more loosely because of the lower height of their rim) and they are sneeze-less.
I have provided dimensions of my portafilter. Could others who may be interested in a naked PF do the same, so we can get a sense of the extent of the variation, if any?
Regards
Timo
Regards
Timo
