timo888 wrote:The thread is M12x1.75 to be compatible with standard handles?
You are correct, for the Cremina's handles. It may be whatever a customer requires.
Cheers
richard
lino wrote:The hardest part of making a PF (if you aren't casting it) is to cut the helix in the PF ears. That helix isn't shown on the drawing above, but I assume that there is one.
lino wrote:Hey Guys,
I figure it's time for me to chime in...snip
Before I get started making too many PFs of different sizes and types, let me slow things down a little...
I'm going to *try* to make a PF for the Cremina. Do they vary by year like the Pavoni? Or is there only one size?
My CNC machine isn't operational yet, and this job requires it, so that's another slowdown.
I've got pretty much no idea of cost right now, except that it will likely be on the far side of $100.
Hopefully I'll have more to add later.
ciao
lino
timo888 wrote:On the choice of material...
The Oly Club manual recommends running the PF under cold water between shots to keep the Club's group from overheating. To that end, could the naked PF be made from brass instead of stainless? Less wear and tear on the group slots too.
Regards
Timo
lino wrote: ... PF for the Cremina. Do they vary by year like the Pavoni? Or is there only one size?
