Olympia Cremina 67 piston seals = Cremina 2011 seals?
Postby Paolo on Mon Aug 29, 2011 6:37 pm
Do current (2011) Creminas have the same piston seal set as the 67 Creminas?
In the archives of my mind I seem to remember reading that the Millenium model had different seals which are now not available from the Olympia factory and that the factory has reverted to using the 67 piston and seals in the current models. Am I imagining things or is this the way that it is? If you could attach a link that exposes all, I would appreciate it.
Cheers,
Paolo
Paolo
Postby uscfroadie on Mon Aug 29, 2011 7:33 pm
Orphanes@OrphanEspresso.com
Barb and Doug can not only answer your question but can also take your order for parts.
Merle
LMWDP #273
uscfroadie
Postby tekomino on Mon Aug 29, 2011 8:06 pm
Yes, 2011 and 67 seals are the same.
Refuse to wing it! http://10000shots.com
tekomino
Postby rawman on Mon Aug 29, 2011 9:34 pm
They are the same style. Are you sure they are the same size? I have both, and thought I measured and found that they were different. Memory may be failing me though.
LMWDP #189
rawman
Postby orphanespresso on Tue Aug 30, 2011 2:55 am
The new and old model seals are identical when you line up one against the other.
orphanespresso
Postby Paolo on Tue Aug 30, 2011 4:08 am
Thanks Doug and others
Paolo
