Olympia Club Restoration DIY Rebuild
I bought this Olympia Club from the bay of evil. The serial number indicates it is a 1971 model. Contacted Olympia directly. They don't have any records as to when they first came out. If anyone knows when they first started making the club that would be great.
It still has original asbestos coating. Unfortunately seals aren't great, leaking steam taps, group leaking. Really nasty black soot coming out of boiler even after several descales.
I thought I will start this thread showing my complete rebuild.
More Pictures inside the machine. Overall I'm hoping machine is in reasonable shape:
Back: Asbestos coating is in good condition
Pressure gauge on top, site glass bottom
I've removed the pressure stat. The bottom black thing is the thermostat. The wiring is a bit burnt and looks like water has got into it at some stage. It will need to be rewired.
Top: Can you see the black soot in the neck of the boiler
Asbestos Removal:
Big problem the two screws which hold the boiler to the frame could not be loosened despite penetrating spray. I did not want to persuade the screws with a hammer fearing I will disturb the asbestos. I also couldn't take the element plate off without disturbing the fibres. I know it is not ideal but I've had to soak the entire frame, element and boiler in water.
DISCLAIMER: If you don't know what you are doing get someone who is experienced in removal of asbestos. I won't go through exactly how I am doing this but suffice to say I wear face mask, disposable overalls and I remove everything underwater so fibres don't get airbourne. Everything will be safely disposed off at the local tip. Asbestos can kill!!!
The shell and boiler currently soaking overnight in a trough of water. I will update when I have made some more progress.....
- farmroast
Suggest getting the heating element plate off. Soaking the outside of the element doesn't seem like a good idea, water might make it's way in. Use a ohm meter to be sure water hasn't gotten in and to see if the element is still ok.
LMWDP #167 "with coffee we create with wine we celebrate"
- orphanespresso
- Sponsor
2 bolts holding the boiler on the frame and 8 to remove the boiler end plate with the element? Seems a small bit to do in avoidance of possibly destroying the element....but it IS your machine after all, and you might have a new element for all I know. Don't know if you can get that one in 220v.
Doug Garrott
www.orphanespresso.com
