esteebie wrote:is it a 'pre millennium la pavoni europiccola'?
That's correct. It should have a 49mm portafilter basket and a two stage switch which controls a 1000W heating element and also a 200W heating element.
Looks like the same machine I have. I have a bunch of videos of it here:
http://www.youtube.com/user/ray5961?feature=mhum#g/uBased on the information I have on my machine, I would guess your machine is from maybe the mid 1970's or some place around there maybe. It's a very well made, good machine, but the learning curve can be pretty steep. Temperature control is also a problem on that machine (in my experience).
As far as a single hole steam tip, check ebay or OE. They sell a single hole steaming tip on there for about $6 as I recall. I have it on my machine and it helps quite a bit.
With regard to steaming milk for latte art, the machine should do it no problem. It's more technique than anything else. I can maybe make a video about how to do it (although, frankly, I'm still learning myself). Here are a few tips:
First, chill the pitcher in the freezer. I keep all my frothing pitchers in the freeze 24/7. Also, use whole milk.
I usually pour the milk into the pitcher, then keep it in the freezer for a couple of minutes until it's time to froth the milk.
Steam on the high setting of course. It should take about 30 to 45 seconds to come up to where you can steam (from when you switch from I to II). Clear the steam wand of any water, then put it about 1/2 an inch under the surface of the milk and turn it on full blast.
Use a thermometer in the milk as you steam. I usually steam to about 130 to 135 and turn off the steam, which causes the milk temperature to coast up to just above 140 degrees F.
Start by steaming with the tip about 1/2" under the surface. Then angle the jet (in my case, from the single tip) towards the side wall of the pitcher. This should create quite a spin in the milk. The important thing to remember, however is this: if you spin the milk, it tends to destroy the micro foam. On the other hand, if you shoot the jet of steam straight down into the milk (less of a whirl pool), then you can end up making too much foam. The result will be that you can't do latte art, because instead of having micro foam, you just have a lot of foam that sort of blops out at the end.
It's a fine line between thick foam, micro foam and no foam. You gotta play around with it. If you spin the milk the whole time, you'll end up with just thin milk and not much foam. If you steam the milk without much of a swirling action, then you'll produce too much foam and it won't be micro foam for doing latte art.
What I usually do is this: start by stretching the milk (put the tip under the surface and get things rolling). Then angle towards the side and spin up the milk and surf the tip a bit near the surface (so that it draws air down into the milk). Then near the end of the steaming, kill the swirling a bit and slow the milk down (steam more down than at the side); you'll see the speed of the whirl pool slow way down. This will tend to produce micro foam more so than spinning the milk around.
So to recap.. I start by spinning the milk and surfing the tip near the surface to pull air down into the milk. Then I back off and slow the whirl pool down (so I can generate some additional foam). If I feel like I have made too much foam, I will swirl the milk a bit to break down some of the foam and pull it back into the milk.
Right now, I'm still fine tuning things. I'll usually still end up with a touch too much foam and not "micro enough". I can almost get latte art, but it's not quite as defined as I would like (I think I'm still over doing it on the foam). It's a very fine line. I'm to the point where I can almost get latte art, but I need to work on my drawing technique a bit further. Also, as you pour the milk into the coffee, you have to pay attention to what you are doing, because if you get things moving around too much in the cup, then it will off balance the pour and you won't be able to fan out the fern (or whatever you are trying to draw).
I'm hoping to get to the point where I can start making some videos soon here.
Also, you need a large, wide mouth cup (at least until you get good). Something which will allow you to pour all the milk you steam without filling up the cup too soon.
Anyway, your La Pavoni (with a single tip) should steam milk with the best of them (so long as your 1000W heating element is in good repair and working okay).
When I first got my machine, I had a heck of a time steaming milk. It wasn't the machine, it was me. Work on your technique and search youtube for videos. You can also use soapy water to practice with, although I have never tried that myself.
Ray
