grong wrote:This sounds good, except that the grind needs to be custom tailored to your specific machine for a quality result.
I agree that dialing in the grind for the current condition of the machine is optimum. However, for evaluating the quality of a <$100 grinder vs. a commercial grind (or even prosumer grind), getting some pre-ground coffee from a shop would be useful. If the shop is using freshly roasted beans, chances are they have their machines roughly dialed in.
So, while you could not tweak the grind to produce an optimum shot, you can still control dosage, and with a lever, pressure. Control over these two variables should enable a pull of sufficient quality to evaluate the grinder.
At least, that's my line of thinking. When i was new to espresso i would have been more willing to spend $5 on freshly roasted, pre-ground (by the shop, at the time of sale) coffee to evaluate my grinder, rather than spending $250 bucks by the recommendation of some people on the internet. Or, i should say, prior to the spending of $250 to buy a grinder. We tend to sink more money into hobbies as time progresses - hence, upgraditis - because we've seen the results so far and can make the decision that it's worth it to continue with better equipment. Still, you see people taking steps with their upgrades, rather than leaps, because of this very reason. (unless they have a lot of cash).
