Hey Doug. Yeah, at it again. And I'll post results of the other rebuilds going on.
But first, a few pics of the Sama. It's such a pretty little machine. A friend of mine picked it up, and we're just doing a basic refurb or fix-up, when we ran immediately into the problem described above. I have been a little too negligent to attend to it yet, but it is next. I need to go get an ampmeter or voltmeter or whatever the electrical tool it to test it as you suggest, which I'll do next.
But first, just for those who want a quick look under the lid, some pictures of the Sama coming apart.
and
and
and under the hood...a very familiar configuration...
and under the base, the wiring....
and I don't know if you can see this, but the boiler is raised up high enough to allow for the electrics to all fit in underneath...
and
All a very elegant little set-up. As I said I have not gone into this machine in depth yet. One problem is the electric one - it is dead right now, although the indicator lights do work. (One is a cheap led light that seems very fragile). So I know I'm going to have to test the leads on the element, but I also want to open up the boiler and check the integrity of the element itself. I worry it may have cracked somehow. To do that you have to peel away the electircs, and then use alan keys on the nuts holding the base of the boiler on, which is also the element (very much like the Cremina configuration). One of ours was stripped, and because they are hard to get to, it is not easy to find a way to get it out. I think I have the solution now, which I'll post about next time I'm on. For now, I want to meditate on the nice trim little design and the overall good health of this specimen. I'm looking forward to getting it up and pumping.
