orphanespresso wrote:You have well illustrated the problem with the cast aluminum boiler machines and it seems more or less unsolvable. An intact boiler in good shape that has been chrome plated may be the only solution in the long run....if you want it to last.
Hi Doug,
With regard to the Lady Duchessa you just restored for me, which has a cast aluminum boiler in good shape, is this a consideration? The boiler on the Duchessa is very thick. What needs to be watched to make sure such a corrosion breakdown doesn't happen? Or on machines like this, should they be emptied after use or have other measures taken short of plating to avoid corrosion?
Later add:
Quick link to summing up MicrocimbaliFor those wanting to see pros and cons of a Microcimbali (older version of Liberty but very similar with lots of interchangeable parts), you can cut to the chase here, where I summarize those after successfully restoring my machine (ignore label on the link, it will take you there):
Newly acquired Microcimbali Liberty: had a few restore questions
