Hey Yall. I just purchased my first espresso machine. A LaPavoni Pro, at a yardsale for less than $50 bucks (I know right!!!). I Drink espresso and think I'm drawing fairly good shots. My Children want me to make them cappuccinos and there lies the problem. Is there any special equipment I need to get to make restaurant like froth? techniques?
You may also want to check out the milk frothing guide on CoffeeGeek as the keys to steaming milk change a little from one machine to another, but the fundamentals don't change too much.
Don't bother with the 3 hole wand I say... Just use the automatic frother that comes with it (or maybe you'll have to get it separately...) It's much easier to use the automatic 'cappucinatore' when you're doing 2 or more milk drinks and you'll get better microfoam than with the 3-hole wand.
Or make your own. Take your wand to a hardware store and get some little capped nuts to match the size. Drill a small hole or too in the nut. Practice frothing until you are satisfied. It works for me.
I found out that the plastic steam wand tip of the Saeco Aroma also fits and works nicely (just mount the inner part, not the additional panarello piece). I am getting much better microfoam than with the 3-hole tip. I assume that also other simple home machines could donate their plastic one hole steam wand end-pieces to La Pavonis.
Or, some folks have simply plugged two of the stock tip's three holes with broken off wooden tooth picks. I haven't tried any of these alternatives, having had adequate success with the three holes...
yeah- I do OK with the standard 3 hole tip. The main thing to let the pressure get high- and then just your basic good frothing technique... The Pavoni's steam quite well IMHO
sorrentinacoffee
Location: Adelaide, South Australia, The Sothern Hemishere, Earth, Solar System, Milky Way, Universe...
Couldn't agree more. Work on technique, not fussing with the wand.
