RCMann wrote:
Another question for those of you who have the machines-I've been using it with the top and side/back cover removed to check for leaks, etc and noticed there's a bit of seepage at times from the pressure relief valve over the top of the sight glass-is this normal? Does adjusting the screw on the assembly at the base of the boiler-the one that has the tube from the pressure relief valve leading to it-affect this? This adjusting mechanism on my machine is actually a knurled knob with a ± arrow indicator on it, which is different from some of the photos I've seen posted here and also different from the 67 tech diagram on the Oly website, both of which show a brass slot head screw.
I've got a complete seal set as well as an extra double basket on the way from Suisse, so replacement of all things organic will be done when I get it. No need to rechrome, that and the SS just needs cleaning and polishing. I'll probably become a Cremina clone and powdercoat the paintwork, and possibly get some of the Thor woodwork as well, if it's not too expensive.
So far, very happy with the machine.
Rod
