gscace wrote:Hi:
Apparently these were seen at the recent HOST show in Milan. The 1-group is of particular interest, although it uses 220V. At 2.7 kW, the heating element should keep up with continuous steaming just fine. I don't know if these are hx or not. I'd think a 115V 1-group machine with 2000W heating element would be very cool.
http://www.fiorenzatocs.com/english/tot_piazza.html
-Greg
Rocket Coffee wrote:In the "benefits" section it's listed as a 110V, so I'm not sure what to think.
http://www.fiorenzatocs.com/engli...iazzasanmarco.html
I believe it uses the same group as my Victoria Arduino which is an HX.
Paul_Pratt wrote:Is it possible to clarify a bit about the group and HX? I have been looking at the NS/VA for some time and was uncertain about the boiler. I can see the group is fixed onto the boiler and had assumed it was a regular pick-up from the boiler, but then on their parts diagram there are what looks to be pipes going to HX fittings at the bottom of the boiler. Their parts catalogue calls it a HX supply tube but no HX in the diagrams.
I just assumed they used a regular HX boiler, removed the HX and left the HX supply pipes to fill the boiler. the leva was a pick-up supply.
Hang on a minute, just checked the diagram again and the autofil is a different route so maybe it does use a HX. So in that case the pick-up tube off the back of the groups go down into the HX? Interesting.
Paul
