Dogshot wrote:I'm convinced that the ideal home machine is a full-size group spring lever. Easy maintenance, no pumps, no noise, no solenoids; just great body and flavour. [...] if Kees [van der Westen] made a 1-group PID'd Idrocompresso, I'd probably have a hard time staying away from it.
On my visit to his workshop (see
Sneak peek at the all new Speedster Mk II) I talked with Kees about such a machine. The problem with the spring-loaded lever at Idrocompresso size is the forces relative to the size/weight of the one-group machine are so high the espresso machine would need to be bolted to the surface it is on or else pulling the lever would tip over the machine.
To Kees, this means he does not explore this alternative. (yes, but ... 's, not to me please)
Regards
Peter
