It is the grey model with thermostat on the back and a ship on the side.
I hope you guys can help me out a little her.
- If the guy is telling the truth -then the machine has not been used in like 30-50 years - and maybe never. What should I do to the seals before use? (I do not have the 111 stuff I read about elsewhere in this forum)
The piston has 2 U seals and there is a small o-ring seal inside the piston. And a hard Portafilter gasket.
- How tight does the seals go when in working condition? If i push the lever down, and close the two holes where the espresso should be coming out if I had water in the tank, I cant build up tight air pressure when lowering the handle. Should air pressure build up in that situation?
(Just tried with boiling water and regular coffee - pressure could be built up and coffee came out - no crema though - guess because regular coffee used?)
- Should the thermostat button also work as on/off button? I can turn the button and push it, however it does not turn the heater and light off (The red light is on and the heating element is heating up regardless how i turn and/or push the button)
Great forum! Your replies appreciated
Kim
