sourland wrote:I'm working to get my old machine up and running. Thanks for all the great info here. Unusual to see so much participation from vendors, thats great!
I determined that my 2 element is bad. It is the old style brass/bronze? base type.
Can anyone tell me if the new ones like this:
http://espressocare.com/Qstore/Qstore.c...nt+4+prong
The one you reference in the link above there is the same one I have on my machine. I have a La Pavoni Europiccola Pre-millenium - probably from around the mid 70's or so. As far as installation, there is a brass ring which screws onto the threads of the boiler itself, then on that ring, there are three threaded holes. Allen screws typically go through the 3 tabs on the boiler element and screw into the ring. There's a little rubber O-ring (I think it was 80 mm in diameter if I recall correctly), which makes a water tight seal (the O-ring goes into the groove you see on the boiler element there).
You would need to take the base off the bottom of your machine (unplug it from the wall first of course) and see what you have. The double boiler machines should have a "I/II" switch and wiring provisions for two different boiler elements (one for brewing and one for steaming).
The two boiler elements you are considering appear to be the same part (as near as I can see). The first link just has a more clear photo I believe.
Ray
