Psyd wrote:Yeah, that could work, but there is very little three-phase in the US that isn't applied to some sort of industry. Mostly the connectors for such things come in large and individual connections, and tapping into it would eventually tick off someone, and probably someone buff and quick to anger. 220V goes to every home (give or take a percentage point) in the US, as two sides of a center-tapped transformer (110V per side). Ignore the center tap and you're right back at the originally transmitted 220V.
And you'd be at 208V off of the three phase, not that it wouldn't work.
zubinpatrick wrote:if the 2 110 legs in the receptacle were the same phase one could be changed in the main panel.
208V would most certainly work since in our home the voltage varies from 210V to 225V depending on where you are, induction between nearby phases etc.
