My first lever- the journey begins - Page 10
I only have the two stock baskets and the two Elektra baskets. They all fit fine.Balthazar_B wrote:Nice fabrication on that portafilter! Do all of your baskets fit well?
Searching for that perfect espresso!
Wachuko - LMWDP #654
- peacecup
I think the stainless pins are more likely to cause wear to the brass group. Or perhaps they do not contact the group because they are enclosed in brass roller bushings?
LMWDP #049
Rear pin will be riding on a needle bearing as soon as the bearing gets here (I am thinking Monday). Front one will not be an issue when I go naked.
- drgary
The pull shouldn't be softer with a naked portafilter (like photo below). Pull shouldn't be stronger than 30 lbs. Jack's right, I think. A brass pin is less likely to cause wear in the piston rod.wachuko wrote:Rear pin will be riding on a needle bearing as soon as the bearing gets here (I am thinking Monday). Front one will not be an issue when I go naked.
LMWDP#308
LMWDP#308
Got my answer from redbone in the other thread. No need for additional holes.
