Paul wrote:Hi All
Just found this forum today. Very exciting. I have been a fan of lever machines for years. My first foray with them was restoring a 3 group carimali (1970's something or rather - maybe 'zema'?). This now takes pride of place in my kitchen and displaces my fridge into the dining room, to my wifes chargrin. Aside from this, I played with a copper europiccola before addiction took over.
I am in the process of recommissioning a 1956 Cimbali Rubino. On checking it over I found that it has no sort of pressure regulation (well, apart from a big honking lead weight that serves as over-pressure). I can't see how this would make it very easy to use. I suppose that since the element is quite low powered (~500 watt) that you regulate the pressure by bleeding steam or changing the boiler water on the fly.
Anyway, I intend to install a new sirai pressurestat, off an existing fitting above the waterline. Also I intend to have a local engineering company replace the element filament to boost capacity to 1500 watts.
I would appreciate any thoughts as to my plans.
Cheers,
Paul
Paul wrote:Thanks for the validation. I was feeling nervous of modifying such a beautiful machine.
Mogogear, have you plumbing in your Gaggia yet? Did you need to regrease anything after 29 years?
cheers
Paul
