mogogear wrote:a small side trip to Olympia produced the hoped for results.
hbuchtel wrote:"Making the impossible possible"What machine were the seals from originally?
I was noticing on the Zerowatt that how far the piston head is screwed onto the shaft determines (obviously) how far down the piston goes.
I think it would be best for it to go as far as possible without hitting the showerscreen, so the displacement is as great as possible...
Of course, the showerscreen is the kind that grips on quite firmly, I don't think it would be possible to push it off from the inside...
Just thinking out loud. Have you put her back together yet?
Henry
mogogear wrote:1.I don't understand your question Henry? The old v seal on the Gaggia didn't match the seals that ASCASo sent me - see the pictures.. of the two seals...
mogogear wrote:2.Remember the farther the piston is "unscrewed" to end up closer to the dispersion screen, the less water it will intake when the piston is raised.. because the piston will be lower at the top of the stroke. I would screw the piston down firmly on the threads on the piston shaft.....
