Very simply, if I keep the tip completely submerged -- even if it's only just barely completely covered in the milk -- I wind up with hot milk. No microfoam. (It seems to me, most of the europiccola frothing videos I've seen keep the tip fairly well submerged, yet somehow wind up with mf. Hmm.)
Of course, if I go the other way, and try to surf, I often wind up with bubbles.
What I've taken to doing is living with the bubbles that sometimes come with surfing, and with the encouragement of the whirlpool effect, and then sinking the tip quickly -- sooner than I used to -- and hoping the bubbles dissipate before the milk gets too thick for art, which is another problem.
Sometimes, I get good results, but the resulting "art" is almost never completely bubble free. Some mornings are better than others...
Now, I've read all the threads, looked at all the videos. I've tried the tip in the center of the pitcher -- where I usually leave it these days -- but I've also tried it against the edge.
Clearly with more powerful machines, microfoam frothing is probably easier. But I know it can be done. You've all said so!
Pouring the actual art is another matter... But please help me consistently achieve "perfect" mf, if you can.
Couple other questions. When I raise the lever and hold it in the up position for the preinfusion, sometimes droplets of water leak from where the piston is exposed by the lever raising, and onto the top of the grouphead -- usually more onto the left side of the gf, but sometimes onto both left and right -- and I wind up repeatedly drying the dripping before pulling the shot. Curiously, this doesn't happen when I pull a blank shot. Ideas?
Often, during the pull, a lot of steam escapes from where the gf is attached to the boiler. I place my left hand on the boiler cap to stabilize the machine, so I often get a mild scalding during the pull. Not so bad as to stop me from doing it, but I'd rather it didn't happen. Never used to. Am I pulling too hard?
Thanks so much for your thoughts on any or all!
