First of all I would like to thank you all for the info provided in various threads here. It was of great value as I reconstructed the machine. I'm not a coffee guru, a Bialetti has up to this point served all my needs. But I am somewhat familiar with machines so I thought it would be a good idea to reconstruct a machine for my girlfriend. So I restored the machine with parts from OrphanEspresso and gave here the Microcimbali as a christmas present. But she is more familiar with professional equipment so we are struggling to get the right results with it. A grinder is not in the budget at the moment so were using preground from a local coffee shop.
The restoration went well, although it was a pain to dissasemble - everything was really stuck together. There was a lot of scale and the boiler has some pits. I did a light descale for a 24 hours and lightly scrubbed with scotch brite but I was afraid to do harm to the boiler so I had to leave some scale. I decided to not remove the cylinder. It did not pop out when I removed the spring and after I tapped it lightly from above to knock it out it did not move. I saw some warnings against knocking it out as it could be impossible to put it back together again as that part seems especially prone because of the thin aluminium the sleeve for the cylinder is made of.
After the restoration I have no leaks, it heats up quickly and seems to build good pressure. I'm still working on polishing the boiler. I was a fool too soak the whole boiler in a light citric acid solution. It did not do good for the outer part of the boiler - i'm still polishing it!
I've followed the instructions on the machine as well as what Doug at OE shows in the youtube video of the Microcimbali. I've managed to get some coffee out of the machine, an "alright" shot on par with crappy machines. Put what concerns me is that I do not get the same lever movement as Doug gets in the youtube video. I have to support the spring on the way up, it does not ease its way up at all. I would like to know how much this is determined by the grind and how I fill the portafilter.
I'm not sure if i'll ever get proper steaming with this machine and I have tried to use it on fulll power - both elements turned on 1300 watts. I can see that the machine is not made for this... As I get water spitting out of the chimney. I get enough heat put very little air into the milk. Do you have any tips on have I could get better results.
It would be very much appreciated if I could get some more detiailed instructions from those of you who have used this machine. How have you achieved your best results?
Thanks again everyone,
Jon.
