this is an early model (i presume), without the bolted top end to the piston body - the piston is removed from below. it also has a large single-piece bronze group head, which screws out of the main aluminium body. if you have one of these and are trying to find ways to disassemble it, look at this older thread - it is REALLY hard after years of corrosion....
and oddly enough, the top bronze bearing for the piston rod and for the lever action seems to have been flowed onto in place during the casting.... there are cup seals below this to the piston rod, so it is not a pressure connection.
this is the machine all apart on my bench. besides the bronze group head, everything was quite easy to get apart.
someone was at it before me - the sight glass was remade in perspex (!) and sealed with copious globules of silicon goo. also, the original drain pipe was likely busted and there is a broken-headed screw plug in a thread repair sealing the hole (if anyone knows where i can get a drain valve with original knob, please pm me!)
the boiler is in decent condition for aluminium - i have soaked it in dilute citric acid and given it a very gentle rub with scotch brite.
the threads to the bronze group head were corroded quite badly, but i have just cleaned them with a gentle wire brushing along the thread line. the two parts now go in by hand. the previous post linked to above shows a tool i had made to apply pressure to get the bronze group head off - LOTS of pressure and hammering and heating. the portafilter still goes in after removing a burr that occurred in the bronze from this reckless masculine pressure.
now it only remains to find the seals (i am asking at orphan espresso, but it is a strange machine and i think i may have to search far abroad) and maybe i will put the elements back in citric acid again to thoroughly descale. i do not plan to repaint - i want it working and as original as possible - i like the wear that tells of a thousand previous coffees made in decades past....
and i have to say, i really don't like aluminium....
