I'll try posting some pics here well see if it works.
Also
ANY AND ALL INFO RE THIS MACHINE APPRECIATED.
It seems to be in really good hardly used shape, no rust and it seems it has a double heating element. The only date I found was '93 re: electrical licensing from Canada/Ontario. The PO says it was run on 20 Amp 110V....Everything inside/outside the box says 220 so maybe a little sleuthing is in order. Possible they have been running it on 110 and getting poor results. I'll probably hook up the gas and see how she goes. Speaking of which, there was a lot of soot on the bottom of the boiler, I'm guessing it was set up for gas and the PO used propane. If the jetting is wrong would that cause soot? I don't really associate soot with either gas but know next to nothing about appliances run on NG/LPG. So far so good. I took it apart a bit to get to know it, but as everything seemed in order I resisted the desire to pull everything apart as then new gaskets etc will be needed.
Here is a link to the site with all the pics I took
http://s392.photobucket.com/albums/pp3/...g%20lever/
