while waiting on spares, we started the big clean-up.
As soon as the ordered 5 kilogram Citric-acid arrived, the boiler,the flanges, piping and heating elements received a thorough (36 Hours) bath in a 15% acidizing solution.
To neutralize the acid everything was then rinsed in a mild Soda-Ash solution.
After the clean-up several broken stud bolts had to be drilled out and renewed, I have decided not to use carbon steel, I got some 8mm 304 stainless studs, incl. washers and nuts at the local hardware store.
Also bought some 3mm thick Klingerit material, to make gaskets out of for the boiler-flange, and levergroup flanges and the heating elements.
Also got me a 100 gram tube Dow Corning 111, locally known as Molykote 111 Compound..
The valves and levergroups will have to wait until parts arrive.
The chassis has been sandblasted and received two layers of undercoating, I reckon there is no need for further corrosion protection there.
Today I made a start assembling the boiler and piping as far as possible.
