Manual levers
Postby farmroast on Sat Feb 12, 2011 4:46 pm
For home use a manual lever seems ultimate in concept for quality and flexibility without getting too pricey. The oly cremina being the best manual lever I know of. Jim Hoffmann did a recent blog entry on Pressure Profiling and referring some to spring levers. I can see where a multi-group spring levers made more sense in most commercial environments to save time than if they were manual. And the learning curve is easier with less human control. And I can see where pump machines replaced spring levers and why pump machine are now getting really complex and expensive. Personally, I have mixed feelings when I walk into a shop and see a new ultra super expensive pump machine. How did manual levers like Creminas and Europiccolas come about? I've never heard of any commercial manual levers. Is that truly the case? But now some shops are using time consuming manual pourovers for brewed. Yet I don't ever expect to see a new commercial build 1 or more group manual lever. But if there was I would most likely want it.
Ed Bourgeois
LMWDP # 167
http://coffee-roasting.blogspot.com/
"Bezzera Strega" the newest WMD in the LMWDP
farmroast
Postby Doolittlej on Sat Feb 12, 2011 5:57 pm
If you are looking for a commercial grade lever machine:
http://www.keesvanderwesten.com/mirage-...resso.html
Jeff
Doolittlej
Postby farmroast on Sat Feb 12, 2011 6:24 pm
Doolittlej wrote:If you are looking for a commercial grade lever machine:
Jeff
But it's a spring lever not a manual one. There are many commercial spring levers.
Ed Bourgeois
LMWDP # 167
farmroast
Postby Bluecold on Sat Feb 12, 2011 8:15 pm
It doesnt seem hard to convert a conti 'linkage' levergroup to fully manual operation by removong the sprimg, rotating the upper assembly 180 degrees and make the lever in line with the upper linkage instead of at a 90 degree angle
I think the manual home lever was invented for easier servicing, lower manufacturing costs and less heigt so they fit easily under cabinets.
LMWDP #232
Bluecold
Postby beanflying on Sat Feb 12, 2011 9:37 pm
There is no way I would want to line up and make 500+ cups a day on a manual lever machine apart from the slow pace your knuckles would be dragging on the ground :roll:
Levers RULE :-)
beanflying
Postby zubinpatrick on Sat Feb 12, 2011 10:03 pm
TRying to make 2 shots, 3 lunches, 4 breakfasts and get out the door by 7:30 has taught me that in a busy place a spring lever really helps. I cannot imagine a commercial location that would want to hire a guy to hang off the lever all day. BTW part of my springless routine involves using my chin to push the lever down as I steam milk.
zubinpatrick
Postby Bob_McBob on Sat Feb 12, 2011 10:37 pm
zubinpatrick wrote:BTW part of my springless routine involves using my chin to push the lever down as I steam milk.
I think we need a video of your espresso preparation routine.
Chris
LMWDP #295
Bob_McBob
Postby KnowGood on Sat Feb 12, 2011 11:07 pm
beanflying wrote:There is no way I would want to line up and make 500+ cups a day on a manual lever machine
Hahahaha - I'd quit my first day!!!
Lyndon
_________
LMWDP #251
KnowGood
Postby beanflying on Sat Feb 12, 2011 11:24 pm
KnowGood wrote:Hahahaha - I'd quit my first day!!
First time I fired up my Izzo commercially we did 20kg in a couple of days 8)
Levers RULE :-)
beanflying
Postby sorrentinacoffee on Sat Feb 12, 2011 11:51 pm
but you had a spring didn't you Bean?
Having used spring levers and manual levers my feeling is spring is best. The manual control part is over-rated: as long as the grind and tamp are correct the pour will be good. A spring allows to to pull the lever and move on.
Having said that the caravel remains one of my favourite machines.
sorrentinacoffee
Location: Adelaide, South Australia, The Sothern Hemishere, Earth, Solar System, Milky Way, Universe...
Next
