Clay as it comes out of the pugger (nicely wedged and 100% de-aired due to wedging under vacuum):
Pug on the wheel:
Rough Thrown (I hate to say it, but these are looking a lot like hornet nests):
Rough Trimmed:
Next steps are to let dry a bit more, clean up, dry, bisque fire, glaze and glaze fire. If it all works out, and everything tests fine for a few weeks on the machine, then I will consider making a very close duplicate of the existing boiler and instead of wheel throwing, I will slip cast it making it look very close to the OEM boiler. To slip cast I need to make a plug (using a wood lathe, I think) the size of the boiler + allow for shrinkage, make a plaster mold and then pour liquid clay into the mold. That's why I can't use an actual boiler for the mold. Or it I did, it would be a bit smaller than the OEM boiler.
What pops out should be very uniform and nice. I will add color to the slip so the clay will be colored all the way through and a clear glaze overcoat. I've never done much slip casting, so this is a nice excuse to learn something new.
I should note that I'm appreciating the basic design of the Peppina more and more. My shots are now all 'tigery" or "tiggery" and it really is a great machine. I'd be interested what Caravel owners who also own a Peppina think as to the pros and cons of the two of them.
One design feature is that the lantern shape of the boiler is purposely designed so that when you press the lever down you don't hit the boiler with your finger tips. I don't know if the ones I threw will work as well in that regard. I could actually 'flat' one side a bit, but I don't think I will. I could also add some text or logos if I felt like it.
dan
