TonerSupply-ISO9001 wrote:2nd item: My company IS a source for Health Dept. certified Food Grade lubricant for your espresso machines. They come in four (4) ounce tubes which should last you quite a long time. I have two varieties. Blue and Red. I'm going to use the Blue on the piston. The Blue material has zero taste, nor contaminates to potentially pass on to the Espresso; The Red is a high heat application material and is more difficult to remove; Also, it contains a small amount of petroleum, so perhaps it is best NOT to use this on the LaPavoni Professional piston above the group head. I'll let you know how it functions.
Best regards to all, Walter
TonerSupply-ISO9001 wrote:The expense is $40 and up depending upon the complexity of what needs to be machined away.
lennoncs wrote:Do you have the NSF group and MSDS for this grease?
cannonfodder wrote:What I used was 'Taylor Lube HP' manufactured by Taylor Co. Rockton IL. It is a food grade lube made for the food service industry to lubricate food processing equipment. One tube contains enough to last about a thousand years. We carry it here at work, but we do not sell to the public so you would have to find a local supplier. Cost is a whopping $1.73.
