Looking for double basket for Conti Comocafe, any suggestions?
Dear fellow lever lovers,
I've got a Conti Comocafe which I quite enjoy using, but unfortunately it only came with an original single basket and a double basket that somewhat fits, but definitely is not original. The single basket has a flat ridge, whereas the double basket has a round ridge and only forms a proper seal when I prop it up with some rubber bands between portafilter and basket.
As I am using the double basket much more frequently than the single, I would like to get one that fits better than the one I have. Any suggestions on which baskets from other machines I could try? Getting an original one would of course be best, but they are probably even rarer than the machine itself...
Any hints would be very much appreciated.
Thanks,
Roland
PS: The Comocafe has a basket diameter of a bit more than 49mm. I have tried a pre-millenium Pavoni basket already, but unfortunately it did not work.
Thanks,
Roland
- crazy4espresso
If you're looking for 45 mm, flat ridge, straight wall baskets, you can try the ones from Zacconi. They may come with dimples on the side, which you may have to grind down, but should work.
Edit: Seems the Comocafe baskets are 49 mm, sorry.
"I would rather suffer with coffee than be senseless." — Napoleon Bonaparte
LMWDP #427
LMWDP #427
- doubleOsoul
In order to answer your question, we need pictures. Lots and lots of pictures. Oh and video too. LOL
www.soulsidecoffee.com LMWDP #354
- Bluecold
How much is 'a bit more than 49mm'?
Apparently, the 51mm Pavoni is about 53mm in reality.
Source for non-Pavoni 51-ish mm millennium baskets?
But some lower end Krups and Sunbeam machines use a 50-51mm basket.
http://thingscoffee.com.au/product_info ... cts_id=109
http://www.brevilleusa.com/single-wall-filters.html
Best of luck in any case.
LMWDP #232
- grog
If you can source a Zacconi aka Riviera 49mm double basket, I can confirm those work in the Comocafe PF. Just used one this morning for
my 6:00 am Comocafe shot in fact. I got mine from the OE closeout extravaganza a couple of years ago, but they may still be in production.
Just make sure you get the 49mm NOT the 45mm. Riviera has made groups and baskets in both sizes. Oddly the Pavoni 49mm baskets do not work in the Comocafe PF.
Here's a supplier in Germany:
http://www.coffeemaker-spareparts.com/Z ... 8d55db10ef
LMWDP #514
- yakster
The Comocafe does have a larger basket than it's inspiration, the La Peppina. I found that out at the 2012 Ides of March Eve Lever Espress Pull-Down at the old Barefoot Coffee location in Santa Clara when mokemo set up his Comocafe next to my La Peppina. I tried the Yak Wack to eject the puck from the basket of the Comocafe keeping my finger on the edge of the basket and it almost flipped out into the waste bucket because of the difference in size.
More pictures here: San Francisco Bay Area Lever fans (LMWDP).
-Chris
LMWDP # 272
LMWDP # 272
Thanks for all the suggestions, I will see that I get a Zacconi and a Krups basket and just give them a try and then report back. Hopefully one of them will fit. The best way to get one of the Krups baskets might be to bid on a broken Krups on ebay, they often go for less than the cost of a spare basket...
Cheers,
Roland
Cheers,
Roland
- yakster
-Chris
LMWDP # 272
LMWDP # 272
