I don't know where you could get a filter basket. Here are the dimensions of the basket on my Caravel in case you find another vintage basket and want to see if it might fit:
Outer diameter at the lip: 52mm (the lip is flat and .8mm thick)
Outer diameter directly below the lip is 45.5mm
It is 45.5mm diameter cylinder for the top ~10mm and then it tapers conically to an outer diameter of 36mm
Height: 26mm
thank you for your suggestion, I will be looking for one and hopefully will find one soon. I can't wait to make a cup of espresso with my machine.
Thanks again.
