www.veniacoffee.com: purveyors of specialty coffee and exceptional equipment
Levers and SO coffee - Page 9
Postby peacecup on Tue Jun 13, 2006 11:01 pm
Hello Karl.
I'm more and more enjoying "cool" shots - I seem to prefer the taste. Another trick you can add is to soak the portafiler in cold water, then engage it. I believe the principle is that a cool group will act as a heat sink - on commercial levers there is enough brass for this to work by air. On our humble home levers we need the additional heat sink of cold water. One last trick I've used is to submerge the lower half of the group in a large cup of cold water.
I saw my first Elektra "in the brass" the other day in Cafe D'Arte in Seattle. I was on my way to the airport so i didn't have much time, but I was impressed by the size - much more substantial than the Pavoni. It would be great to try one sometime.
I plan to try home roasting over my gas barbeque sometime soon,
PC
LMWDP #049
peacecup
Postby KarlSchneider on Wed Jun 14, 2006 8:22 pm
peacecup wrote:Hello Karl.
I'm more and more enjoying "cool" shots - I seem to prefer the taste. PC
PC,
Tonight i had three more pulls. The second, un-cooled was already tasting too hot. The third I used my latest cooling with a wet sponge on the brass connections between the group and the boiler. A short time of sizzling sponge resulted in a perfect third pull. These FTO Ethiopia DP Sidamo's are wonderful. All the flavors sing together. The basic coffee is a light earthiness. The second flavor is soft chocolate. If I had a coffee cafe this would be my standard. But I would want to then diverge from this point.
I seem to be the defender of the Elektra. It is no chore to do so. I love its appearance above all the others which I have seen only in pictures and never held in my hands. I have never had better espresso. I cannot speak to longevity. I have had mine for less than a year. I still want to try a manual lever because Steve Robinson has persuaded me to do so. I am open to being surprised that a Cremina pulls better shots.
KS
LMWDP # 008
KarlSchneider
Postby espressoperson on Thu Jun 15, 2006 8:55 pm
KarlSchneider wrote:I seem to be the defender of the Elektra. It is no chore to do so. I love its appearance above all the others which I have seen only in pictures and never held in my hands. I have never had better espresso. I cannot speak to longevity. I have had mine for less than a year. I still want to try a manual lever because Steve Robinson has persuaded me to do so. I am open to being surprised that a Cremina pulls better shots.
KS
Karl,
IMO there is no question the Elektra wins for beauty. Perhaps only surpassed by a Kees van der Westen machine. As for the difference between the Cremina and the Elektra, like you I have no direct experience. However, I think that one factor in addition to the spring is the beefiness of the machine that allows you to take it to the edge without stalling or stressing it.
You can typically pull the classic lever shot, smooth, sweet, clean, but perhaps a bit light on crema and mouthfeel. But you can also push the machine to produce a pump-like shot, lots of crema, tiger flecks, rich mouthfeel, but perhaps less smoothness and clarity to the taste. And every once in a while an elusive shot that is the best of both. Of course you can also pull a 5 second bubbling 4 oz gusher or a 40 second overextracted 1/2 oz cup of goop if all factors are not aligned.
I've seen and tasted enough world class espresso to know that the Cremina produces output in that class. Of course, proof of existence needs only one shot to make that statement true. There are days when I may have three shots in that class. But then there may be days when I will not come close at all. Happily, the misses are eminently drinkable. And intermittent reinforcement is a more powerful motivator of behavior than constant reinforcement :-).
MichaelB, LMWDP #24, PHAROS #019
espressoperson
Postby cannonfodder on Thu Jun 15, 2006 11:16 pm
KarlSchneider wrote: I still want to try a manual lever because Steve Robinson has persuaded me to do so. I am open to being surprised that a Cremina pulls better shots.
KS
Evening Professor.
If you want to try a full manual, you are welcome to try out my Gaggia Factory (LaPav Pro in disguise). We never have gotten together. It sounds like a fun Saturday evening get together or I could loan it to you for a week.
cannonfodder
Postby jrtatl on Fri Jun 16, 2006 10:58 pm
srobinson wrote:I wanted to start a new thread to talk about enjoying Single Origin coffees on the lever machines. I am beginning to believe that a great lever and a SO is a decedent combination.
Wow, I know I'm over 6 months late in responding to the OP, but the lawyer in me really wanted to point out that "decedent" means a "dead person." hehehehehehehehehehehehehehehehehehe
I know I have nothing of value to add to this thread, but I hope my maniacal laughter provided some comic relief.
Jeremy
jrtatl
Postby KarlSchneider on Mon Jun 19, 2006 8:11 pm
peacecup wrote:Karl,
I've noted that you've expressed interest in a Cremina - I would really like to see a comparison of the Elektra and the Cremina. I strongly suspect that the Elektra would hold its own.
Also, you've discussed over-heating. Have you tried cooling the group with a wet towel. The large group on the Elektra appears to be designed to mimic those of commercial levers - they sink heat to keep temperature stable. I've noticed that I can keep my PV at my preferred brew temperature by just cooling the group a bit between later shots.
PC
PC,
Again tonight 3 Yemen Mokha Sana'ani remind so clearly of my need to thank you. I continue to use a cold wet sponge to cool the group on Niccolo Amati between the 2nd and 3rd shots (and 3 /4) and it works extremely well. It essentially eliminates the overheating I taste if I do not do this. A very simple solution. Elegant simplicity.
It appears I am getting a Cremina. I am quite excited about sharing my tastings of the differences between my Elektra and the Cremina as I can taste them. It may take me a while to get the "hang" of the Cremina. With ca. >1500 pulls on the Elektra I think I am moving from "kennen" to "wissen" (or, conocer to saber / connaitre to savoir). I hope the Cremina learning curve is shorter.
KS
LMWDP # 008
KarlSchneider
Postby peacecup on Tue Jun 20, 2006 7:55 pm
Karl,
Actually, I've just nominated you for Mo's Hall of Fame:
http://www.home-barista.com/forum...of-fame-t1741.html
Your focus on tasting has helped my barista skills immeasurably. Although I love all that chrome (or brass) I'm really after espresso. Which is why I'm writing - my espressi today have all been doppio - I've written on the relative merits of dose elsewhere (see solo or doppio), but today I want to make another note about cooling the group. I pulled four doppios today on the PV (and one on my Estro just to compare - it didn't). The second to last PV doppio was quite hot, and consequently a "window" shot (no sink in my office). I cooled the group, tightened up the grind, and pulled by far the best shot of the day. The upshot is that a faster pour will be hotter, not cooler, because it has less time in contact with the heat sink (group). Very interesting... and tasty!
So glad you'll be getting to try a Cremina - I'm looking forward to your review!
PC
LMWDP #049
peacecup
Postby peacecup on Wed Jul 12, 2006 3:06 pm
I have begun roasting my own. In a cast iron pan on my electric stovetop. I eventually hope to go to a small drum on the gas barbie. I started with a Yemen Moka, which I've learned tends to roast unevenly. Can anyone tell me how long it should take to bring it to a full city or slightly beyond? How long to first and second crack? I read somewhere that the beans should start in the cool pan and be brought up to temperature. Is this correct?
Is there a better bean to learn on then the Yemen?
Thanks,
PC
LMWDP #049
peacecup
Postby KarlSchneider on Wed Jul 12, 2006 8:19 pm
peacecup wrote:I have begun roasting my own. In a cast iron pan on my electric stovetop. I eventually hope to go to a small drum on the gas barbie. I started with a Yemen Moka, which I've learned tends to roast unevenly. Can anyone tell me how long it should take to bring it to a full city or slightly beyond? How long to first and second crack? I read somewhere that the beans should start in the cool pan and be brought up to temperature. Is this correct?
Thanks,
PC
Hey PC, I am sure you will love roasting your own. I wish I could give you guidelines but my experience is limited to drum roasters (Alp and Hottop). On both all I can say that might help is that it takes about 2 min. from the start of first crack to the start of second. One has to be careful about defining "start." I never consider the very first crack I hear a start. I wait until I get 3 & 4 close together. 2 min. after that the second usually starts. But this interval varies from bean to bean.
Yes Yemen beans roast irregularly. This makes the start of each crack harder to define. The sound of each crack is quite different. The first is pronounced like breaking a pencil. The second is much more quiet more like a snap on a shirt than a crack. You will hear them easily after a few tries.
Full City is just before second crack starts. I take my roasts well beyond. To rapid second crack. But I prefer oily beans.
I recommend using a timer and a log in which you record times for each crack. I record start of first / start of second and end of roasting. My first cracks start at 15 min on the Hottop. Second starts around 17 and I end roasting at 18+. In the Hottop one starts by adding room temp beans to a drum warmed for 5 min. I think I would warm the cast iron pan a bit before adding beans.
Experiment and taste.
KS
LMWDP # 008
KarlSchneider
Postby MachoSilvia on Fri Jun 01, 2007 8:43 pm
Well, im not a lever user (yet), but then again its about the coffee, not the machinery, right? but I too am beginning to explore SOs more thoroughly. I have Sumatra Mandheling, and Ethiopian Yirgacheffe, in copious amounts; I have blended them 50-50 at times, but find that I can appreciate their flavours as a SO much more at the moment. My palate isnt excellent by any standard; I have tried about 6 other beans previously and have explored them rather inefficiently, but recently, with the two I have settled on, I am learning a lot more about what each bean likes as far as roasting, degassing, dosing and grinding.
I found the Yirgacheffe, until yesterday, to be very bright, very sour, if used in espresso too soon. Yesterdays yirgacheffe espresso, was roasted just before the rolling second crack, it progressed slower than usual, about 45 seconds from the start of the second crack, 3 days of degassing, had a very light taste, with what i can only describe as a very 'fresh' finish. I cant describe the specific flavours, since my palate isnt fantastic, but I found the yirgacheffe to be very delicate. This one was down dosed, with a finer grind, highlight the brighter notes.
Im interested to see what others have to say about these two coffees, and their plan of attack.
"Join Me, i will teach you the dark side of the force"
MachoSilvia
PreviousNext
