peacecup wrote:Karl,
Long time no post. Glad to see the SO thread is alive and well. I've been sampling some locally-roasted Sanani over the past month, and I've really enjoyed it. I credit this thread for piquing my interest in SO's. I hope to begin roasting my own at some point. Although I have a great local roaster who roasts to order, I still don't have the ultimate control over roast time, etc. that is really required for the type of subtleties you describe.
I've noted that you've expressed interest in a Cremina - I would really like to see a comparison of the Elektra and the Cremina. I strongly suspect that the Elektra would hold its own.
Also, you've discussed over-heating. Have you tried cooling the group with a wet towel. The large group on the Elektra appears to be designed to mimic those of commercial levers - they sink heat to keep temperature stable. I've noticed that I can keep my PV at my preferred brew temperature by just cooling the group a bit between later shots.
PC
PC
KarlSchneider wrote:Roasted two Brazil's today. My intended espresso roast for the week is an SO Faz Brauna Peaberry which SM's says in natural pulped. My Americano roast is an Org/FT Poco Fundo. Since I have never had the F. Brauna I had to try it at a mere 4 hours after roast. The first cup went into a heavy IPA Illy Logo because I expected Brazilian heaviness. I was much surprised by what I think was the best espresso I have had from any roast at such an early stage. Amazing balance and developed complexity. The shot ran a bit fast so I decided to "get more extraction" and set the grind finer and tamped harder. I succeeded in getting a slower flow. I also got an overextracted cup with a bitter tone in the finish that was wholly absent in the first cup. Here too there seems to be a sweet spot of level of extraction -- an Aristotelian mean between the extremes which is different or each roast (each day?). A final Yemen of last week's roast was fine but I think my Elektra was a bit too hot and I had a burnt taste in the end.
KS
KarlSchneider wrote:I can imagine a parallel post to Dan's "How I learned to stop worrying and love an HX (a home lever)." While intrigued by the buzz here for commercial levers I am not yet convinced they are the answer. My basic hesitations so far are cost, size and necessity of plumbing. I keep thinking they are comparable, for me, to getting a Hummer to go two miles to the grocery.
KS
