ronbeso wrote:For the first few shots, the lever would quickly lower itself as the machine was heating up and pressure built up. But recently, the lever stays in the up position as the water is heating, causing the hot water to drip out of the head and into the drip tray. If I lower the handle manually prior to start-up, all works well and the shot comes out perfectly
Cameron,
Sounds like your lube job went well, so congrats on tackling this yourself. As Barb/Doug pointed out, your machine is working as it should. As for the hot water coming out of the grouphead as your machine is heating up; that's because when the lever raised upon cool down it did so so rapidly that it stopped above the inlet port in the grouphead. Pushing the lever down just a tad will block the port and prevent this from happening. You also could just partially open the steam wand after you are done pulling shots to allow the boiler to vent just a tad of pressure. Just don't leave it open, turn on your machine, and walk away. If you do, you may end up with your machine venting steam until there is no more water in the boiler and your heating element trips the thermal fuse to prevent a total meltdown.
Just sayin...it's been done before.
