I own a Conti Prestina which is a fairly robust single group machine that lacks some of the prettiness of Faemas etc. It is a "
flush to warm the group machine" with ~ 20+ pounds of brass group and lever stuff hanging out in the breeze. That means that it is most happy with back to back shots and then the group is very stable.
It is a manual fill machine and has a 5 liter boiler and only ~1Kw of power. At home I have it set to 1.0 bar for the few shots in a day that I may pull.
If I take it to an event, I amp up the pressurestat to about 1.2 or 1.3. That keeps the boiler heat on a bit longer and allows me to add boiler water from the Flojet® between shots. I can pull about 2 shots or more in three minutes at that setting. The 5gal. bottle is at room temp so there is not a great amount of heat needed to keep the machine operating.
Cheers
-Richard
