another_jim wrote:The spring is equivalent to a weight on the cylinder (and I don't want to see any pictures of groups with barbells instread of levers!).
another_jim wrote:The pressure is the same anywhere under the spring to the top of the puck (just like a hydraulic pump which changes crossection area to get mechanical advantage) -- so one only needs to worry about the cylinder's diameter for pressure calculations, not the puck or basket.
The spring is equivalent to a weight on the cylinder (and I don't want to see any pictures of groups with barbells instread of levers!). The brewing pressure is the weight divided by the cylinder area.
another_jim wrote:A hydraulic pump (from grade school physics):
Take a 1 inch cross-section tube, press on it with 1 pound -- have it make a u-turn and flare out to 100 square inches. The water will be at 1 psi throughout the system, and the 100 sq inch side will lift 100 pounds. Obviously, you have to press down 100 inches to lift the other side 1 inch.
The pressure is equal throughout the sealed part of the system, cylinder bottom to puck top. So that pressure will be the force on the cylinder divided by its surface area, regardless of what happens lower down. A narrow cylinder means more piston travel for the same amount of coffee, but less force -- the total amount of energy required is the same.
