To test the theories discussed in my earlier post I performed two temperature tests on the Ponte Vecchio Export (PVE) as shown below:
In both tests the boiler was filled just to the top of the sight glass. The machine turned on, false pressure released and left until the heater idled on and off for about a minute. In each test the water from the grouphead (no filter basket) was collected into a styrofoam cup with a thermometer pierced into its side about 1/8" from the bottom of the cup. This thermometer was tested beforehand in boiling water at about 150 feet above sea level and read 210 degree Fahrenheit. All the numbers are as tested are in degrees Fahrenheit.
TEST 1 (4 oz of water per pull)
1. 2 minutes at idle from startup 191
2. 3 minutes later 188
At this point the water was below the opening in the boiler flange so I waited 30 minutes hoping to prove one of my theories
3. 30 minutes from sample 2 193
4. Last pull because boiler water is below the sight glass 190
Not many data points. Obviously the 4 oz water sample was too large so did a second test this time with less water and after the boiler was rinsed many times with cold water bringing the grouphead back to room temperature. The following test are 2 oz per pull.
TEST 2 (2 oz of water per pull)
1. 2 minutes at idle from startup 186
2. 3 minutes later 189
3. 3 minutes later 186
4. 3 minutes later 190
At this point the water was below the opening in the boiler flange but I did not wait 30 minutes. Just kept on sampling every 3 minutes until the boiler water did not show in the sight glass
5. 3 minutes later 191
6. 3 minutes later 192
7. 3 minutes later 191
8. 3 minutes later and water at bottom of sight glass 190
The experiments are not sophisticated. The numbers are as read and do not have the 2 degree offset due to the thermometer reading 210 degrees instead of 212 in boiling water. Also I would strongly suspect that the temperature the coffee grounds experience is higher due to the evaporative cooling of the water stream as it falls into the cup. Maybe this can be offset by pressure stat adjustment? And speaking of pressure stats, I do not know the boiler pressure but soon will and will post it accordingly.
The numbers are very interesting. There is no evidence to my theory that the water will be cooler when it gets below the opening in the grouphead flange. The flange modifications I suggested in my earlier posts are unnecessary. So much for theories
But I think this shows reasonable evidence that the grouphead of the PVE overheats very little during the of making coffee at regular intervals. Which I hope answers zubinpatrick's original question.
What is also interesting, this data correlates well with peacecup's and my experiences with the PVE. For we have both found from the cup the need to pull a couple of warming shots to get that loverly dark crema on the first shot. And the data also shows that we can most likely can get 5 more
