www.zokacoffee.com: you're original, drink like it - single origin & artisan coffee
A leva water smells like burnt plastic - Page 2
Postby Fullsack on Tue Aug 04, 2009 8:31 pm
Thanks Doug, I was almost out of moves, thought dropping the pstat to .9 from the factory setting which was high, about 1.3, but not sure that would have done the trick, thought a cooler machine might not get the rubber hot enough to smell.
I've had good luck carefully manipulating seals into place with the blade of a screwdriver, once they are in the slot.
Doug Jamieson
http://www.fullsackjack.com/
LMWDP #017
Oh yeah, it's deliziosa!
Fullsack
Previous
