As so many others have written before, I do apologize if this is too common or not really anything that goes beyond what's normal for this machine, but I have indeed tried my best to figure this out and read through this and many other forums now for weeks. I got this machine about a month ago and a few things I can't get my head around. When you raise the lever after pressure has been reached, it first splashes out water once (quite a bit before reaching the fully "up" position, and then the flow slightly halts, before dispersing more water again continually until you pull the lever down again.
It seems to me as this should only be happening in one go, right?
I have for sure had problems getting a decent shot out of the machine, and I think in general there might be something wrong with it (it is 2nd hand, and I don't know if the gaskets have ever been replaced, but the ring one sitting on/around the dispersion screen seems to be alright?), because it also seems to be running hot/overpressurized. It's mentioned everywhere that this is commonplace, and some people even turn it off for a bit after it reaches full pressure before pulling a shot, but my pressure meter goes all the way up to 1,5 bar (way up in the red zone). If I do turn it off and wait long enough for the pressure to start to fall, then there is not enough to make the water rush through into the group. So yes, two problems I suppose but the water dispersion issue seems strangest, at least to me, since I never tried one of these before. I thought, that the water was only supposed to start to flow at the very top lever position. Thanks any input is greatly appreciated and sorry for the lengthy post
