LaPavoni 49MM double basket..whats your dose?
Postby mindless_fool on Fri Mar 19, 2010 7:57 pm
trying to figure out where to start with a pre millennium pavoni dose. dont want to waste a whole lot of coffee and i will be using a hand grinder (will be using it out of town on vacation).. so whats your dose. I will be using Black Cat.
Thanks..
mindless_fool
Postby SAS on Fri Mar 19, 2010 9:43 pm
I use a TWO Tablespoon measure and scoop up beans slightly more than level. This yields about 12-13 grams of beans which I grind. I find the 14 gram dose too big for the system.
Basket filled with grinds.
After tamping.
LMWDP #280
Running on fumes...
SAS
Postby KnowGood on Sun Mar 21, 2010 2:46 pm
I'm using 14.3g to accompany lossage with NO HEADROOM, with the final ground dose in basket being 14.1g:
With no headroom the dispersion screen does a final tamp of roughly 2mm. You need not to worry about disturbance to the puck because you have left no room for this to happen:
I am grinding with a Kyocera hand grinder, and using a bit coarser of a grind - between 160-170 turns to be exact of Detour Coffee's Punch Buggy espresso blend. Detour is out of Dundas and you can pick up his stuff at Darkhorse.
Lyndon
_________
LMWDP #251
KnowGood
