Lambro upgrade - Page 3
Upgrade is done. PID works perfect. Using Volvic mineral water. Coffee tastes great, very clear, no more laurel liquorice.
Mission accomplished!
P-Stat has gone. There is almost nothing left inside the machine. I mounted a little alu-box where I put the electric connections and the SSR. The SSR doesn't click. So the machine is completely silent. A big difference with P-stat control. Pressure doesnt drop, so I have a good pre-infusion pressure constantly.
I tried to get stainless steel tubes, but the shop didnt have the right size tools to make the narrow curves. I also tried to replace the thermosyphon tubes with ptfe-tubes. That also didn't work out yet. PTFE is too stiff to make the narrow turns and I did not find a supplier that had the right fittings. But I think I leave it like this. The espresso is already sooo much better now.
Hi NelisB that Lambro is at a whole other level. The upgrade looks amazing. Can I ask about the nickel plating and how that is with descaling? Have you had any issues?
- dmccallum
Impressive indeed.
Would you mind sharing your PID component list ?
NelisB wrote:Upgrade is done. PID works perfect. Using Volvic mineral water. Coffee tastes great, very clear, no more laurel liquorice.
<image>
Does your machine have auto fill? Where is manual boiler fill lever?
It looks like people in the US could potentially do their own nickel and/or chrome plating.
http://www.caswellplating.com/
Superb work.
Could you give me the reference of the steam wand?
I want to change mine on my Lambro too.
Thx
Thx
I too would be interested in the PID components you chose.dmccallum wrote:Impressive indeed.
The nickle plating is high phosphorus electroless nickle. About 50 micron. That should be completely sealing the copper from the water.noddyc43 wrote:Hi NelisB that Lambro is at a whole other level. The upgrade looks amazing. Can I ask about the nickel plating and how that is with descaling? Have you had any issues?
The high phosphor is recommended to prevent from corrosion. I have not descaled yet, but the water I use now should not leave much scale in the boiler.
I have to look it up. The pid is Storktronic ST24 PID. You won't find it on the internet though. a PT100 for measuring the temperature, a SSR. I'll get back on the brands and numbers...
Steam wand and tap is from Kees vd WestenEmeric wrote:Superb work.
Thx
