ademello72 wrote:Hi Simon,
Good Luck with the heating element fix - I have a similar need - While I was away last week, the machine was used, left on or the water was too low or something (still getting the details) but anyway, the heating element is done, multiple splits all along the coil - I'd be interested to see if you have found a way / come across other Riviera users who have successfully replaced / fixed their heating elements to get their machines working again.
I' just looked back at the photos you previously posted, and I see your pstat is a little different from mine - I'll post pictures when I am home again.
Also, on the cleaning / polishing of the brass and copper, what did you use? It looks really really nice - The colour of the level looks a little different, and mine is also showing a slight colour difference. Do you also have any clear coating on the machine, and how did you remove it before polishing?
Sorry for all the questions, it looks like I may have some time on my hand looking after the "cosmetic" aspects of the machine, as I search for a replacement heating element
Will post pictures soon
Thanks
Anthony
For all the technical glitches and saves, Anthony asks the question about the #1 time waster on this kind of refurb, and that is how to polish that much BRASS. Even though I'm replying 3 months later, it's worth replying to (sorry Anthony). My forearms are now twice the size and my squash game has improved. If I can find a better way next time I'll use it, but here is what happened.
1. I was warned against bathing the group and other parts in citric acid or rubbing with lemon juice and salt, because it would colour the part differently than the other brass parts (more orange than gold/yellow?). So I didnt use citric for this one, although I'd be very tempted to try on the next one, and if you have copper/brass materials on different parts of your machine, might be worth a try -- because the thing will be "two tone" anyway.
2. I used a version of a tarnish remover (Tarnex) for the "first pass" as each major part -- boiler, group, base -- to get off the green oxidized mess and just get it to a more or less uniform dull brown brass. Check out the early posts for how it was out of the box. I used about 30 rags up in the process, a plastic scrub brush for really sticky parts, and my trusty brass brush (ever so lightly) for the really touchy parts and corners. If I knew of one, I'd use an even stronger tarnish remover. The basic method with that stuff is to wipe it on, let it sit briefly, and wash it off in warm water, and repeat, and repeat, and repeat.
3. For all internal cleaning and de-calcification and "under the hood" scraping and scratching, wire brushes, usually the circular ones that can be attached to my hand drill. There are some really funky attachments you can get now that permit drilling at angles and lots of brush shapes and sizes, and not too expensive (5 or 10 bucks), and they save a lot of time. A couple of really useful hand brushes as well, as I have been saying.
4. Once the initial de-tarnishing is done, I used brasso to bring it up to a shine. Yep, brasso. I know it sounds insane, but that's what I did. Each little brass piece in the group and on the exterior I "brassoed" to a respectable level of cleanliness. For things that went under the hood, I didn't need perfect shine, but I needed completely free of grime or anything that would wear or jam the machine. For anything external, you need bling-level of polish. I actually found that it was not physically hard, as much as time-consuming, so I spent a few evenings on the couch with my rags and brasso watching hockey. The main thing about brasso is that it brings grime off pretty good, but it very quickly uses up a rag which then needs cleaning -- so it can only clean off one part, and then needs cleaning itself, in order to be really effective. You'll see what I mean if you try it. So, lots of bleached laundry. All of this added a new dimension to my primary relationships, that is, wife and daughter, who now have several IOUs stashed away. I figure, you pay either way.
5. Once the brass parts get to a near-bling polish, they get finger-printy pretty easly and dull down pretty quickly, but can be brought back up easily with a quick polish. It is maintenance, another reason why I'm so pleased to be giving this machine a deserving home that is not mine. But I suppose it is worth it to have the wow factor when the buddies come over and see this bad boy sitting at the end of the counter or wherever you keep it.
That is how this one got polished. I need a better method for next time, but for posterity, there it is.
