The work has actually been moving along. And I'm on the last leg of a holiday, computer in tow, so I'm able to spend a couple of minutes updating you on progress and getting some more details down.
You may recall there were two main problems with the rebuild: a sheared/stripped thread issue in the steam valve pipe where it screwed into the boiler, and the electrical leads on the heating element snapped off flush with the element's face. Actually, not quite with the face, because the outside of the element has two protruding receptacles cast into the aluminum, about 3-4mm wide and maybe 7mm tall, within which ceramic (insulators?) surrounded the electric leads. But more about that later.
Despite the delays, the boiler problem was a fairly simple fix. A local machine shop (Custom Prototypes) re-drilled the threads and made a new steam valve pipe of the same dimensions for a very reasonable cost. They brazed a nut onto the pipe and we did have the discussion about appropriate brazing materials (food grade work) and the pressure it would operate at (normally 1-2 bars, but 3 bars to be safe). I don't have pictures on my computer now but will post them when I get home.
The second problem was the snapped leads, and here I am trying a bit of a speculative solution creating insulated steel sheaths that fit over the nubs of the leads. It is unstable and possibly unsafe, and so I am trying to find a way to make it mechanically more reliable and do a little due diligence on the electrical issues to make sure I don't kill the element, machine, myself or someone else.
While all that cogitating is going on, I decided to go ahead and clean the group and piston and replace the seals, and that part is what I'm posting about today, to give you a look at the cleaned and re-built group and seals, and to share the tips on getting it done.
First, a fuzzy shot of the piston I think I posted before that shows it as I pulled it out of the group when I stripped the machine.
Grungy. I used a pick tool to remove the seals and polished the piston up. A small brass brush and a lot of brass polish worked pretty well to get the dirt and hardened rubber out of the grooves and I brought it to a decent shine. The head of the piston looked like this after a decent rub.
Note the four little holes. These are also found on the Cremina and they permit water the flow through the head where it will hit the first seal (shown below). I believe Steve R speculated that these holes permitted water to force the seal to flare out and make a tighter seal against the cylinder when applying pressure.
Next, the piston with the new seals on. This piston is a 3-seal configuration. As you can see, the first two are together and flare out and away from each other, as you would see in most piston assemblies. The third is inserted in the same orientation as the first, flaring out and down. I'll speculate on that in a second.
The Riviera uses a spring-pressure lever (more pic below of same) which requires you to pull down on the lever to raise the piston head and permit the group to fill with water. Releasing the lever then lets the spring push the head back down and push the water through the portafilter. It is in this second step that the four holes pictured above function to flare the seal. The third or top seal stops any leakage through to the top of the group around the piston warm. There is no other seal between the piston arm and the top of the group-head, which makes this design actually very simple and elegant. I can't comment on functionality until I begin to draw, but conceptually it is nice and simple.
Finally, a shot of the group spring alone.
The rest of the assembly is pretty simple. The most work went into cleaning and polishing the group head inside and out. I used a food-grade metal cleaner for a first pass, and then brass polish for the next few passes to bring it out. Inside the group head cylinder, I used a finer brass brush to remove the build-up on the cylinder. No magic to it, it just takes a few hours polishing while watching re-runs.
Here is a shot of the mount of the group head that fits to the boiler, just for interest.
And once all the polishing was done, I inserted the group-portafilter seal.
Now, the trickiest part of the re-assembly of the group is the re-insertion of the piston and spring into the group, and fixing on the lever. This is tricky in spring levers because the spring wants to push the piston down, and you want to push against it up, so the piston rod pushes up and through the group, where you can then fix the lever on to the top of the piston rod with the pins and c-clips. If you had three hands it would be pretty straightforward.
First a quick shot of the spring inside the group.
And then inserting the piston, which will push without resistance up to the level seen in the photograph.
I use a food-grade natural oil along the sides of the group and the sides of the piston to make sure it went through easily.
At this stage, there was a little serendipity. The new seals require a little convincing to fit neatly into the group head cylinder. The first time I did this, as I worked them gently in and pushed the piston up, the seals had sufficient grip against the cylinder walls to resist the pressure of the spring forcing the piston head down (with slight help from a thumb kept firmly on the piston from below). This is of tremendous help if you can push the piston far enough up to fix the lever on to the rod with the pins. It makes the job very simple.
If you can't, or, if you're like, and you assembled and disassembled it several times to make sure it was right, very quickly the seals do not provide the same grip they did the first time, and the spring works properly to push the piston head down, just short of flush with the cylinder lip, as in the picture above.
First thing to do it ensure the piston rod is inserted in an orientation such that, when the piston rod pushes through the top of the group, the hole in the piston rod will be properly aligned to permit the lever to be placed on top and pins inserted. Make sure to do this, or you'll be re-doing this whole process to get it right.
Now, with the seals already neatly tucked into the cylinder, you need to push the piston head up a sufficient distance to push the rod through to the top of the group and even further, to permit affixing the lever properly. I used a small, thick wooden dowling capped with a bit of felt to avoid scratches to the piston head. The diameter of the dowling was about 4-5cm and it was 8cm long. I set the dowling on the floor, placed the group on top of it, and pushed it gently down so the piston rod was forced up a sufficient distance. I then used one free hand to hold it and the other to align the lever with the holes in the top of the piston rod, and then to push through the pins. Make sure again to push the pins through and settle them where they need to rest, because as soon as you release the group and the spring exerts its pressure they will be difficult to move laterally. When you're ready, release the pressure and let the spring push the piston down, until the lever is engaged. Now fix on the c-clips to the pins, and you should be done the hardest part. See the picture below.
And the other side.
And with this done, you have just one more happy task to finish the group: snap on the dispersion screen. The one I had from the machine was in good shape, except for the black grunge in the screen. So I spent an hour with a pick pushing the grunge out of every hole and cleaning it with metal polish, while watching "Burn After Reading", so it didn't annoy me too greatly. The screen itself is sturdy. You can snap it on to the group head cylinder pretty easily with your thumbs, or give it a gentle nudge with the rubber mallet. Then, it looks like this:
And voila, you are done the group re-assembly.
When I get home, I'll be able to finish and show the work on the boiler, and hopefully execute the Macgyver fix on the heating element, and then we'll be very close to a full re-assembly.
I have a few emails and comments from other Riviera owners and re-builders, most of which I have not had a chance to reply to yet. I will consolidate the information in them and post it as well, and reply to you. Sorry for the delays.
But, meanwhile, I'm going to the beach.
