OK, maybe this pic will make it more clear:
Springs and Pistons
That's the LaPeppina on the right. It's one big mamma of a spring, granted it's a bigger diameter piston, but I think it's still running a higher pressure. There is also a HUGE preload on that spring. The Microcasa, granted with a "clapped-out" spring on this one, has almost no preload.
LaPeppina also moves about 2oz per lever pull (measured with no coffee, no PF).
'Nuther neat feature is that there is a check valve on the output of the cylinder going to the grouphead. This means that if you do a double pull, or a half pull for pre infuse, you can pull it as fast as you like because it doesn't put a vacuum on the top of the puck. No chance of breaking its seal. I like that.
I've only run two shots thru after I cleaned it (it's in amazing shape considering it's age), my original intent was just as early "play with it" shots, not really trying to dial it in or do anything carefully.
Coffee is Black Cat (roasted 9/1) and grinder is a doserless SJ
The first run stalled. Probably due to the fine grind and the 130# tamp ( the "1" isn't a typo).
I had to tamp with the small end of a plastic tamper for a Krups, so I guess I over compensated.
The second pull, I made the grind a little coarser and tamped a little looser. Did a 1/4 pull to get a pre-infuse and purge the air in the lines...
Now, I've been drinking swill from a limping, in-need-of-help *$ Barista, so I could be "uncalibrated", but I also have some VERY fine shots of some VERY fine coffee pulled by some very fine HBs, on a VERY nice LM every Friday.
I'd match the second pull up against the best of those.
Now all the above happened over the course of 1 hour.
That's:
unpacking
disassembly
cleaning / degreasing
regreasing
figuring out how to re-assemble
re-assembling
"hot-wiring" (didn't come with a cord)
pumping with vinegar
rinsing out vinegar
heating up
then pulling shots...
I had between 4:46 and 4:57 to pull those before I had to run out the door.
Tomorrow (well, maybe tonight, but I won't drink 'em) I'll pull some more with pics.
The second pull was crema full height until just before the pull ended (I didn't time it).
Hmm,
Can anyone tell I'm excited?
And the MicroCimbali should arrive in less than a week...
ciao
