jobober wrote:I'll give timo's suggestion a try as soon as possible, but it makes me think that I was possibly using too much coffee? I guess I thought a dose of that size would be nowhere near enough to get a decently long pull. I was using a variety of home-roasted single-origin coffee for a while, but when I was having some trouble improving the shots I got a few pounds of black cat just to keep that one variable consistent.
chidofu wrote:My totally uneducated guess at how to get a puck instead of puck soup is to add more grounds and tamp it well so that when you release the lever arm you get resistance and can let go of the lever completely. This is indicative of pressure building up in the system, which puts pressure on the grounds in the portafilter and creates a harder puck at the completion of the pull.
I grind so that the loose grounds completely fill the portafilter and then tamp. I have also found that I need to do two partial pulls after the coffee has started to come out in order to create the pressure on the lever that is so critical to a successful pull. If I release the lever right after the coffee appears, it generally wants to go immediately back to the upright position with no resistance.
