La Pavoni top cap thread size
Postby BramJ on Sat Dec 17, 2011 4:01 am
For a little project I want to replace the top cap of my La Pavoni Professional but I can't seem to find fittings that screw right in, does anyone know the size of the thread of the top cap?
I want to add a temperature sensor (attached to the top cap, but so that the sensor itself is positioned in the middle of the boiler and a way to add a air pump to pressurize the boiler at temperatures below boiling point
BramJ
Postby coelcanth on Sun Dec 18, 2011 2:59 pm
it's a metric thread,
the cap is 31mm in diameter
so i guess it'd be called
M31 x 2.0mm
i don't think you'll have much luck finding an off the shelf part to fit
coelcanth
www.ajcoffeeco.com: excellent coffee without compromise
Postby benhogan on Sun Dec 18, 2011 3:14 pm
that sounds like quite the project. I'd love to see it. Please post as you put together.
benhogan
Postby BramJ on Sun Dec 18, 2011 5:21 pm
hmm, M31x2
doesn't look like a standard size indeed...
This project is kinda a first step for a bigger project where I want to make a machine based on 2 pavoni's, one for the espresso's and one for steaming/hot water
BramJ
Postby RayJohns on Sun Dec 18, 2011 6:47 pm
I think it's probably M32 x 2.00, which is a standard size. There's a slight taper also, but I don't know if it is pipe threads or not. It's definitely 2.00 mm pitch.
Ray
RayJohns
Postby coelcanth on Tue Dec 20, 2011 2:06 am
well mine measures 31mm with no taper..
anyway, it looks like the only thing 32x2 is commonly used for is plugs in motorcycle gearboxes.
i see lots of links for 'brass vent plugs' but only in minimum orders of 1000 or so.
but here is a link to one as used on a bmw S1000RR:
http://www.bmwmcchattanooga.com/showAss...bly=478747
no mention of material, though, and i think it will be too tight a fit..
but it's only four dollars...
if you are going to undertake your own machine project, it might be worth making connection with a local machinist that can easily turn simple parts like these when you need them. can you find people like that in Europe ? they are a dying breed in the US. here you are best off learning to do these things yourself...
coelcanth
Postby BramJ on Tue Dec 20, 2011 5:15 am
I was hoping I could just simply buy a piece, but that seems not so easy...
My brother has a lathe and we also have one at work, so those are the next options
Mine seems more like 31 too, as far as I can measure here :P
I really need to get a caliper to do some accurate measurements
BramJ
Postby RayJohns on Tue Dec 20, 2011 11:23 am
I measured mine using digital calipers. As I recall, it was ~ 31.8 mm near the top (by the sealing O-ring) and more around 31.5 at the start of the threads. That let's out any sort of 31 mm threads in my book.
I have a jewelers lathe here, but it's not setup for cutting threads. For cutting threads, I find it's easier to use taps and dies most of the time. For M32x2, however (especially given the depth of the thread on that top), I think it would probably require a larger lathe or fixture than what I have here.
Ray
RayJohns
Postby rpavlis on Fri Mar 02, 2012 7:17 pm
I just received an M32x2 die in the mail. Its thread matches the Europiccola boiler cap perfectly. I found it at an eBay store from China. It is my intension to try to machine one of the chunks of polyetherimide that I have to make a base for a boiler cap to which to attach a wood one. Die stocks for large dies like this are expensive, but because polymers are not as hard as steel, I think I will be able to turn it with a pliers. The hard part is getting it started absolutely straight. I think I have a large aluminium block somewhere, perhaps I could make a die stock from it, but I do not think that will be necessary.
Assuming that I can succeed in cutting threads in the pieces of polymer I have, I also need to figure out how to attach the wood top to the polymer.
rpavlis
Postby TomC on Sat Mar 03, 2012 2:07 am
^ This would be awesome. I was just telling Ray how much I'd like a temp probe sitting right in the middle of the boiler. I imagine one could be made that could sit in the center, yet not need to actually be wrenched on, itself to take the top off.
Fresh out of the roaster: SM Ethiopian Yirg Grade 1, Compass Ethiopian Sidama
Next batch: Guatemala Geisha...
TomC
Next
