by uscfroadie on Fri Jan 21, 2011 4:08 pm
If your shots are sour, your group head is NOT overheating; quite the opposite. If you could post a video of your routine it would be easier to help pinpoint the cause. Without that, here's my $.02...
beans - great!!
grinder - good
pressurestat setting - good, provided it's accurate
routine - dunno....
on my Pav I would turn it on and let it heat up, bleed false pressure (usually next to none (La Pav Pro/Gaggia Factory), and pull about 4 ounces of water through the group prior to making the first shot. I'd use this water to do two things: warm the group head, and warm up my cup.
Here's a way to see if your group head is not hot enough for your pull. Follow your current routine and drink or sink your first shot, but before doing that, take note of the color of the crema. Is it yellow, tan, speckled tan/brown, dark brown, black? Now, leaving the machine turned on, pull a new shot. Is this second shot better? Is the crema different? If so, how? Yellow to light brown is too cool, thus sour. Tan with brown speckling is usually perfect. And dark brown is usually too hot, which will produce bitter shots. You'll need to tweak your routine to match your machine.
I don't see (read) anything wrong with your current routine that would be an obvious flaw, thus the steps above to try to help narrow down the cause.
Merle
LMWDP #273
