Hey Gonzalo!
Two things to double check before messing with the thermostat (usually called the "pstat" if you search the forum) :
Make sure that the water tank is 80 - 90% filled, AND make sure that you have released what is called 'false pressure' before trying to pull a shot. To do this: when the heating element clicks off (the light goes off), open the steam valve for 4 seconds or so to release built-up air pressure inside. The heating element will kick on again. Close the valve. Wait for it to heat up again. Only now will you get an accurate pressure reading for pulling a shot.
If you are doing the above already, it does sound like the pstat is set too low.
BUT... I would suggest pulling a shot at the pressure at which it is set to see if you like it. Make sure that the portafilter is hot before pulling the shot (run hot water through the empty pf, then dry it off, put the ground coffee in, tamp and pull) ... If it tastes sour, then adjust the pstat upwards. But if it tastes fine, leave it. People honestly differ in how much pressure they like. There is also an interaction between the coffee you are using and the temp you want... (this is part of the fun of a lever machine -- you can play with all the variables.) I like one coffee (a single origin Ethiopian that is not too darkly roasted) that tastes amazing at a lower temp/pressure than the darker roast I usually drink.
The pressure 'stat (pStat) can be seen on the following page:
Removing the base and adjusting boiler pressure on a Pavoni?You turn the black dial to adjust the pressure. Adjust it slightly, wait for the machine to cycle off and on again, then recheck the pressure.
The pStat is accessible by removing the base. This is easy on a pre-milenium machine -- it doesn't need the special screwdriver hex thingy that they discuss on that page. It may be as simple as removing the drip tray and unscrewing the regular screw there...
REMEMBER: the right pressure is the one that gives you the taste YOU want.
Have FUN!
Just my 2 cents.
Michael
(1999 Pavoni Pro, and my trusty 1981 Cremina Olympia. Original owner of both. Love them both.)
