La Pavoni Pro heating element
Postby mitmind on Mon Aug 08, 2011 6:40 am
Hi
I'm in the middle of rebuilding a pre-milenium LP p16, one of the down sides was the heating element "death"
I was looking for some non OEM options to avoid 150$ xDD and i finally found this
http://www.spanglefish.com/avicennassol...eid=243553
I make some modifications to keep a little part of the old resistor because I don't have welding machine
First I cut the old element,
Then and very carefully I drill the 10mm holes using of course different sizes of drills ( 2, 4 , 6 , 8 , 10 )
I use some power control unit to reduce the RPM of the driller to avoid deformations on the holes.
now Its time to clean everything and mount the new one :P
And some leak and temperature tests
And heating element DONE ! !
1.0 Bar Perfect ! !
I've read lot's but until I burned myself I cant believe how HOT it gets ! !
Now I'm waiting for the new brass piston to complete the full gasket upgrade ;-)
Thank's guys for this outstanding forum
mitmind
Postby uscfroadie on Mon Aug 08, 2011 8:36 am
nice work! keep us posted on the long-term reliability of the seals at the bottom of the heating element.
Merle
LMWDP #273
uscfroadie
